It is currently Wed Jun 19, 2013 4:00 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: center cutting form tools
PostPosted: Thu Feb 23, 2012 5:48 pm
Offline
I want to add the center cutting form tools to my tool data base. does anyone have a copy of the standard profiles used to do the tiles which we got in the seminar in Las Vegas that I can get a copy of and add without doing something I will regret and break the tools. I want to do some of the tiles and have the bits. just want them in the tool library so that I can modify if needed. thanks
_________________
Dale Grabowski
Grandpa's Pastime
Top
 Profile
 Post subject: Re: center cutting form tools
PostPosted: Thu Feb 23, 2012 6:06 pm
Offline
Dale,
There are 26 sample tiles on the DVD you got in Las Vegas, of which I recall 4 were cut as samples. Take a look at these and find the designs you like, then see what is required for bits to machine them.
The attached tool file contains all the pointed roundover bits made by Whiteside, which are the ones I have. You can import them into your tool database, but they are not 100% accurate in that I modeled them to come to an exact point, which they don't - there is a small flat center region which I just compensate for using an allowance offset in the toolpath. So, use at your own risk. (It is a very small file, but I had to zip it to find an extension the forum would allow).
Tim
Roundover bits.zip [4.48 KiB]
Downloaded 143 times
Top
 Profile
PostPosted: Thu Feb 23, 2012 6:14 pm
Offline
And here are the actual profiles I used in a .crv3d file in case you want to verify or modify:
Tim
Whiteside roundover bit profiles.crv3d [94 KiB]
Downloaded 157 times
Top
 Profile
PostPosted: Thu Feb 23, 2012 6:47 pm
Offline
Exactly what I was looking for................... My wifw wants all of them cut and daughters do to. guess I will be byst for a couple of days or more. thanks
_________________
Dale Grabowski
Grandpa's Pastime
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
