Chair/step ladder new photos and download zip file
- dhellew2
Finished with teak/tung oil.
Young = time, no money
Old = money, no time
Dale
Dale
- dhellew2
Re: Chair/step ladder new photos
Here are three files for the chair/step ladder.
NOTE: Back and stretcher are thicker to accommodate 1/2" dowels.
NOTE: Check all tool paths for your material thickness.
After v-carving and cutting out the back and stretcher I ran the stretcher through the planer to make it 3/4" thick
The second file is the chair bottom for both left and right sides
The third file is the sides for the back/ladder. You will need to flip the left side horizontal and create the right side.
Dale
Dale
Dale
Dale
Re: Chair/step ladder new photos and download zip file
Chair looks great Dale.
Thanks for sharing the file.
James D. Jones
- Model of CNC Machine: CNC router
Beautiful design & workmanship.
Thanks a lot for sharing!
RickO
Thanks for sharing the files, unfortunately I don't have Aspire. I have V-carve so is there any way to convert this to work in VCP. Thanks for any input.
Thanks for sharing your files.
Scott
Scott
- Model of CNC Machine: Techno LC4896
Dale,
Thanks for the new details. I currently have six chair/step ladders in progress. Building three for my granddaughters and three additional for friends grandchildren. The chairs will cost me a few bucks but a fun project to do between jobs.
Don
Don
Great design. Had some students spot this and we've done a couple of prototypes with some minor changes of your design. Instead of doweling the back into place, we created pockets and lengthened the back to match the depth of the pockets. This eliminated the nessary drilling and positioning of the back. We also tipped the chair back an additional 5 or 6 degrees...my students thought the prototype was too steep.
To convert to VCPro, download the original .dxfs and then it's easy to create the profiles or pockets in VCPro.
- rbrague
Sounds great
Would you mind sharing your improved design?
Rick
Rick
Rick
I don't want to hijack Dale's project or take over his thread. I had 2 students spot the original post in December and it took off from there. They made a prototype in mdf from Dale's .dxf files and then some very slight changes and a second mdf prototype. Here is some of their work done in Inventor.
Inspiration comes from many on here.
Thanks Dale
Thanks Dale
- Franklin Chair Assembly.pdf
- (183.04 KiB) Downloaded 1305 times
- Sub-Assemblies.pdf
- (174.06 KiB) Downloaded 1118 times
- Part Details.pdf
- (73.44 KiB) Downloaded 1116 times
- rbrague
Thanks Gary and Dale -
Great Project -- Kudos to your students as well.......
Rick
Here are the Aspire files that we used. Once again, Thanks Dale. Great work.
- Rside_Back_Trim.crv3d
- (723 KiB) Downloaded 947 times
- Left Side.crv3d
- (219.5 KiB) Downloaded 756 times
- Lower left side.crv3d
- (166 KiB) Downloaded 740 times
- Lower right side.crv3d
- (172.5 KiB) Downloaded 807 times
Thanks guys!
Grabbed a copy for future use!
Ken Zey
Rogers, AR
http://www.CedarSlabSigns.com
http://www.lookoutmercantile.com
Shopbot PRS Alpha 72x144
Rogers, AR
- sawmiller
thanks for all the work, grabed both, i like the pocket idea better, but might cut both
In the heart of Tn
In the heart of Tn
- zeeway
Thank you both for sharing.
Angie
Angie
