Here are almost all clocks I have made for the moment.
Guess which one is not my
Big wall of clocks
- Model of CNC Machine: home made
Big wall of clocks
https://www.etsy.com/shop/3dforcnc
https://www.etsy.com/shop/LVwoodworks
Aspire 4.0, Mach 3
Aspire 4.0, Mach 3
Re: Big wall of clocks
Can just say i like,your clocks are beautiful.
Jonas
Jonas
- Ms Wolffie
The china plate one?
Cheers
Wolffie
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
Those a pretty nice. How did you get them to all have the same time almost down to the second?
- Model of CNC Machine: CAMaster MC4848
Nice clocks, I especially like the walnut ones that are out of round. Very interesting design.
Good work.
Mark
Good work.
Mark
Thanks for compliments.
dond52 - clocks are without batteries .
All clocks are carved in ash wood , the upper three lines of clocks are V-bit carved , stained dark and after sanded out , without coating, because coating reduce contrast of design.
The lower line of clocks are made from two parts - outside part with numbers and center, carved with 1.58mm ( 1/16") tapered ball nose bit , sanded , stained , again sanded and coated with Liberon beeswax.
Sorry if my explain is not in perfect English
And here is one more clock carved in oak wood , not from this wall .
Valdis.
Valdis.
Aspire 4.0, Mach 3
Aspire 4.0, Mach 3
- Model of CNC Machine: Joes Evo 3x2
Any chance you could post a close up pic of the third clock from the right on the bottom row? I have a suspicion of that clock that I would like to confirm.
Edit: Nevermind, I saved and zoomed the picture. It's not what I thought it was. Beautiful work, though.
Those are very nice.!!!
Kelly
Kelly
Dyna CNC Plasma/Router
USAF-- Fadal 4020, Shopbot PRT 4X8
I like the style of your clocks. I visited your website and like what I saw.
Tony
Tony
