It is currently Sun May 19, 2013 9:51 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
Author Message
 Post subject:
PostPosted: Sat Dec 15, 2007 1:11 am
Offline
VCarve Apprentice
Thanks Bill. It looks like very fine, dark lines around all the places where the depth changes. There's no actual dirt, it just looks that way. I'll have to try what you suggest.
Denver
Top
 Profile
 Post subject:
PostPosted: Sat Dec 15, 2007 1:17 am
Offline
VCarve Wizard
I know it isn't dirt, but I think it is small burs of corian, the scrubbing seems to de-bur it some. The clear coat gets rid most of the rest.
_________________
Bill Schober
http://www.humblesticks.com
Top
 Profile
 Post subject:
PostPosted: Mon Dec 17, 2007 2:49 am
Offline
VCarve Apprentice
It wasn't clear from my original question that this isn't really dirt, it just looks like it, so I thought I would clarify that for anyone else reading this later.
I also think it's small burs and ridges. Scrubbing and coating does indeed improve things - more on some images than others. I have a 1/16" tapered ball nose that I'm going to try, and compare the results.
Denver
Top
 Profile
 Post subject:
PostPosted: Mon Jan 07, 2008 7:33 pm
Offline
VCarve Craftsman
I found its important to get feeds and spindle speed right because corian is more scrylic resin than powdered stone. I found I got a lot of "remelt" powder when I had my spindle speed too high. I also found I could fix this by using a nylon, brass or fine strand stainless brush on it and knock it away. I used harbor freight's detail brushes...99 cents for a nylon, brass and stainless detail brush set (59 cents on sale).
Top
 Profile
 Post subject:
PostPosted: Fri Jun 13, 2008 1:23 pm
Offline
VCarve Wizard
Hi all hope everyone is doing well!!
I'm getting ready to cut my first litho and for the life of me I can not understand the zero depth at -.100. I understand why, but where do I set this???
Thanks for any help!!!
olf20
Top
 Profile
 Post subject:
PostPosted: Fri Jun 13, 2008 3:48 pm
Offline
VCarve Wizard
Set your depth (Z) to 0.0 on the surface of you piece then move away from the piece and lower the the Z axis to -0.1 and reset Z it to zero...and there you go Z zero is now at -0.1! Raise the Z up enough to clear the piece and load your file and cut away!!
Bill
_________________
Bill Schober
Top
 Profile
 Post subject:
PostPosted: Fri Jun 13, 2008 11:23 pm
Offline
VCarve Wizard
Hello Bill,
I just set my Max cut depth to 0.2 and set tool pass depth to .2 this gives me the one pass and I zero right on the material. so far so good :)
isn't this giving me the same thing as you are doing ?
Top
 Profile
 Post subject:
PostPosted: Fri Jun 27, 2008 11:58 am
Offline
VCarve Wizard
Hi all, hope everyone is doing well!!
mjc117, what substrate did you use to mount your LED's in???
I have ordered 20 and was wondering what I should use. I'm going to mount the Litho in a picture frame.
olf20
Top
 Profile
 Post subject:
PostPosted: Sun Jul 27, 2008 2:22 pm
Offline
VCarve Wizard
Bill or anybody,
What exact conical bits are you using?
Where did you purchase them?
I have some conical bits (.125 shaft), but I think they are to delicate to be cutting into corian.
My other .25 conical does'nt have a real sharp point.
It is flat on the bottom of the conical. More for countersinking screws.
Any help appreciated.
Top
 Profile
 Post subject:
PostPosted: Sun Jul 27, 2008 4:48 pm
Offline
VCarve Wizard
I use 30 degree bit from centeriontools
here is link to first litho I made it has pictures of the bit and link to the site
http://vectric.com/forum/viewtopic.php? ... highlight=
Hope that helps .
Top
 Profile
 Post subject:
PostPosted: Mon Jul 28, 2008 1:28 am
Offline
VCarve Wizard
Kent,
Thanks for the link..
I really like your nite light.
Curious, looks like you made 3 layers for the nite light. Why 3 layers?
Top
 Profile
 Post subject:
PostPosted: Mon Jul 28, 2008 10:50 pm
Offline
VCarve Wizard
Yep Grease , Three layers. crv file 4th entry in this thread http://vectric.com/forum/viewtopic.php? ... highlight=
Why, cause at the time thats only way I could figure out how to do it.
I originaly made it out of 0.5 inch corian. I thought it to heavy,so made out of the cherry . I was/am a newb when it comes to all this stuff, and not smart enough to go thru the tutorials... I learn as I go :)
Glad you like the night light. It got me some browny points with mom it is her parents. I did a Rectangular one for my father with his parents. I was real happy these as they were my first lithos ....
Top
 Profile
 Post subject: Re: A lithophane without a roughing toolpath on 1/4" corian
PostPosted: Sun Mar 07, 2010 4:51 am
Offline
Can you direct me in how to do a lithopane from Aspire? I don't have photovcarve.
david
Top
 Profile
PostPosted: Sun Mar 07, 2010 9:05 am
Offline
I hope this thread helps. Joe explained how to configure.
http://www.vectric.com/forum/viewtopic.php?f=16&t=3953
Hiroki
_________________
All I can do is carving. Carving makes me HAPPY!
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
