making of 3d sign
making of 3d sign
Hi all
winter time is a good season to try new things. I wanted to do real 3d signs so i took the challange.As a starter i would like to thank Aspire crew to have achieved such a great software,and proof of it follows.
I had an order for a sign for a butcher shop. The idea came from one sign Dan Sawatsky have done,i don't think Dan would disaprouved of taking idea from him,someone told me one day if you are to copy,do copy from the best.
So i search on Turbosquid and found a bull that suited my goal. I did not know if it would work,because the design was an .OBJ. Brought it to Aspire and was able to work my way and after was only a question of using the slice program.
And it did great
We will be installing the sign this coming friday. Pictures will follow after it is install. Meanwhile here are
some pictures on the process.
I am open to commentary.
And it did great
I rather be the leader,than the follower
- mezalick
Re: making of 3d sign
Commentary? you want commentary.
Well, it looks great !!!
Well done !.
I can't wait to see the finished install.
Michael
Well done !.
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
Thanks Michael
i WOULD LIKE TO POST A PRE INSTALLING PICTURE BUT IT IS TO BIG, WE ARE ONLY ALLOWED UNDER 2MB, how do i reduce it so i could post it.Gerry
- T.R.MacMunn
- Model of CNC Machine: CAMaster MC4836
Gerry, that's awesome. Absolutely awesome...........
- rscrawford
- Model of CNC Machine: CAMaster Cobra 408 ATC, ShopSabre IS408
That is superb! Can't wait to see the finished sign. You are raising the bar here for dimensional work.
I hope they appreciate the work that went into it (and pay you accordingly!)
Russell Crawford
Fantastic work, Gerry....
Looks like the model was pretty high quality also
- mezalick
I use Photoshop to reduce my photos, but there are other programs that can do that.
If you want , send it to me and I'll resize it and either resend to you or I could post it for you. Many people would love to see it.
Michael
mezalick@nni.com
Michael
mezalick@nni.com
Gerry Perrault wrote:Thanks Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- Model of CNC Machine: Home built designs - 3'x4' and 5'x12'
MS Paint can do it easily and it's included in Windows. Open a photo with Paint, click on Resize, select Pixels instead of the default Percentage, and change the larger of the two pixel sizes to 1024. Keep the Maintain aspect ratio option check marked or it will distort the image by only scaling one direction. It will scale the image up or down to 1024 pixels. Then save the image, or save it to another name so that you don't overwrite the original image file.
I use Paint to crop screen captures also. Ctrl-Alt-PrntScrn will capture the active window, or Ctrl-Shift-PrntScrn will capture the whole desktop.
CarveOne
CarveOne
CarveOne
Thank you everyone for the good words and advice, here is a preview before installation. Gerry
That is terrific .. well done! To top this you will have to go to animatronics ... Maybe the Granby Zoo should be on your client list!
<we lived in St. Elie / Kateville / Cookshire for 16 years ... you are in one of my favourite corners of the world>
Cheers!
Cheers!
Paul Rowntree
Thank you Paul
We have met at John Murphy get together i am the frenchie that came from Granby,i am doing a lot of things for the Granby Zoo, my next post will relate of my last job for them.
They are having a new exhibit this spring, red panda, this animal is in great danger of extinction, i have done 40 chinese lantern. to be followed.Gerry
- Model of CNC Machine: 2014 roc-tech 4x8 with servos
did you use a coating on the Styrofoam?
http://www.3dsigncamp.com
http://www.roctechusacnc.com
Of course Gerry! I am glad to see that you and your work are doing well.Gerry Perrault wrote:Thank you Paul
Cheers!
Paul Rowntree
For Rej
yes i have use a coating on my styrofoam,it is from DEmand product called
''Elasta-shield''. I put 3layers of that product, Since styrofoam is white i have tinted it with a colour like yellow ochre for the first layer and white on the second one.
Remember this sign is for interior,if this one been for exterior i would have use kind of plastic or urethane.
www.demandproducts.com
- Model of CNC Machine: AXYZ 5010
