complex inlay with engraving
Commission in process, --here's the top to a box I'm making. Materials are thick veneers of : bubinga, arraracanga, ebony, maple, west indian satinwood, baliwood, holly and ivory. Many hours into this top, but I learned a lot, and feel like I can take on complicated inlays with confidence. Both conventional and Vinlay techniques used. Overall size is about 8" x 11", so the celtic banding in the oval is made from lines about 1/32" wide. Banding was based on a free celtic design font I found on the web --easily then converted into the oval configuration by shaping text to curve tool.
I thought this was supposed to make life easier?
- Model of CNC Machine: Camaster stinger III x3 with recoil lath
Re: complex inlay with engraving
could you go into more detail what vinlay is
- Model of CNC Machine: 2014 roc-tech 4x8 with servos
one word - awesome
http://www.3dsigncamp.com
http://www.roctechusacnc.com
- Model of CNC Machine: CAMaster 508 ATC + Rotary
That is really nice inlay work .... WOW
Mick Martin
Aspire 4.015
http://mickmartinwoodworking.com/
Aspire 4.015
Very impressive!!!
- GripUs
Okay...NOW I am impressed! Great work.
Joe
Joe
Ham and eggs - Inconvenient for the chicken. A total commitment for the pig.
http://www.gripus.com/
- zeeway
Beautiful work. Hope someone is paying you well.
Angie
Angie
Outstanding!!
Phil
Phil
WoW!
Ken Zey
Rogers, AR
http://www.CedarSlabSigns.com
http://www.lookoutmercantile.com
Shopbot PRS Alpha 72x144
Rogers, AR
- dealguy11
That is amazing work! Thanks so much for sharing.
A couple of questions
1. What parts were V-inlay versus conventional inlay?
2. For the v-inlay portions, how do you remove the waste? This has always been the part that messes up my attempts, as the inlay chips out when I attempt it. I've tried machining it on my cnc - don't have a drum sander or radial saw.
Steve Godding
- Model of CNC Machine: shopbot PRT Alpha 96x48
I think I hurt myself when my jaw hit the floor. Incredible!
Stars, and both sets of knotwork are Vinlay. I sand off waste with a widebelt sander, 60 grit. If area is small I just handplane, scrape, and orbital sand, but on this piece it was wide belt. Not as severe as one might think, as i resaw the material for male Vinlay at .09 and glue to backer board and resaw layer after routing, so not much to sand off. For the oval banding I glued up a .09 thick oval about 3/4" wide of ebony in segments, and left some of the backer board, pine, when i resawed after routing. Its very cool when i sand down to the inlays , still protruding some, and I can peel off the bulk of the backing layer like some sort of exotic, very dry fruit.
- mtylerfl
Unbelievably beautiful! Wow!
Great work wow. I have some old real ivory piano keys. how hard it it to work with ivory?
The bar keeps getting higher and higher - excellent work.
V Carve Pro Cut 3d
