Celtic Themed Sideboard created using Aspire
- Model of CNC Machine: Shopbot 5 by 10 ATC
I am new to the forum but have been using Aspire software for a number of years.
- Model of CNC Machine: 2014 roc-tech 4x8 with servos
Re: Celtic Themed Sideboard created using Aspire
pretty awesome.
how many hours of cutting did that take?
http://www.3dsigncamp.com
http://www.roctechusacnc.com
35 hours of machine time. It was quite the project.
That is beautiful Daniel!
Paul Rowntree
Very nice indeed sir!
- Model of CNC Machine: Two machines, CRP 48x96 and a xylotex
Very nice job.
- Model of CNC Machine: Laguna Swift
Are the doors raised panel? Mind sharing some details as to how you constructed them? Awesome design and fantastic work. 135 hours of machine is serious dedication to a project.
Mike
Mike
The doors are cope and stick build with a solid center panel. Once door was constructed I carved out the panel section. On the center doors I used the same build, but after I carved the part I ran it thru the table saw and split the door. Really gave it a unique look.
- Model of CNC Machine: Shark Pro Plus
WOW ! That's fantastic ! Thanks for sharing.
Eric
The WoodEraser
Liberty Twp (N. of Cincinnati & S. of Dayton) Ohio
The WoodEraser
- DDWALKER
- Model of CNC Machine: Homemade-Running Mach3
Very nice project, I enjoy all of the details, thanks for sharing.
-David
-David
- Ms Wolffie
Looks great butdanielbf wrote:The doors are cope and stick build with a solid center panel. Once door was constructed I carved out the panel section. On the center doors I used the same build, but after I carved the part I ran it thru the table saw and split the door. Really gave it a unique look.
How did you keep the centre panels in place?
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- gordread
- Model of CNC Machine: CNC Professor HDX
Wow. Amazing work.
Thank you for posting.
Gordon
Gordon
- Model of CNC Machine: EZ-Router
WOW!! Indeed… This will surely become a family heirloom
Joz
Joz
