This video quickly shows the process of creating an Open Sign project. Starting with the job setup, importing and tracing a bitmap, creating the rest of the needed vectors, and then showing you the benefits of adding a clearance tool to a standard VCarving toolpath. We will also touch on the Chamfer toolpath to bevel the edge and then use the Drill toolpath to add holes so we can hang it. Ending up cutting the edited design in the Vectric Lab so you can see it finished.
