Robin
Welcome to the Labs sessions! I’m Beki, a Senior Application Engineer for Vectric. I love to make and I am here to provide you with FREE Christmas projects that you can download and cut yourself ready for Christmas gifts or decorations.
Each project comes with its own video for you to watch that tells the story of what I am making from start to finish. Including technical software footage, machining the parts in the Labs, finishing the projects and I’ll throw a few tips in based on my experience! Each project comes with the file(s) for you to download from your V&CO account, along with a PDF document that highlights some of the key important steps to help you get through your project. Share what you’ve made on the Vectric Forum.
IMPORTANT: If you plan to cut this project please ensure that you recalculate all toolpaths using settings that are safe and appropriate for your machine, the tools you have and the material you are using. You also need to ensure that you run appropriate test parts for the slot together sections of the design before running the files provided. When using the Resin to fill the texture pattern only use the resin as per the manufacturer’s recommendations.
Terms of Use: The projects and artwork are provided on the understanding that they will only be used with Vectric software programs. You may use the designs to carve parts for sale but the Files and/or Vectors, Components or Toolpaths within them (or any derivatives) may not be converted to other formats, sold to, or shared with anyone else. This project is Copyright – Vectric Ltd.
Suitable for version 9 or greater
