Easy Shop Stool
Everyone needs a shop stool… and this one could not be any easier to make. Todd takes you through the design process from scratch taking advantage of the sheets feature and use the initial sheet as a design space.
Once the design is complete in its raw form, we look at what needs to be done to insure the top fits the legs perfectly. Taking in account the material thickness and the geometry of the tool Todd updates the slots (pockets) and tabs so everything should work perfect.
Nearly all of this can now happen in the 3D view thanks to the updates in v12.5. Interactive filleting, guide lines, node editing and much more can now be done in the same view making your workflow easier and faster.
Whether you're a seasoned user or brand new and exploring with our trial software, this project is perfect for you. It's Trial Friendly and designed to help you create something beautiful and functional with confidence.
To help Todd has included a 4 files:
  • Trial Friendly file for 18mm ply
  • Trial Friendly file for .75” ply
  • Trial Friendly file he creates in the video
  • A file ready for our core software owners to edit to fit any thickness of material
Jump in, unleash your creativity, and see what’s possible with the power of Vectric.
Stay inspired. Stay curious. Keep creating!
Todd
Compatibilidad del proyecto
Cut2D Pro Icon
Cut2D Desktop Icon
Elementos que necesitarás
1/4” Compression Endmill
60 degree V-Bit
Información adicional
1 – 20” x 20” x 0.7” Plywood
1 – 15” x15” x 0.7” Plywood
Your choice of finishes
Archivo de proyecto
