Anfang des Jahres trafen wir Dean Makes, einen unserer liebsten CNC-Enthusiasten aus Großbritannien! Dean ist ein Wochenend-Enthusiast in der Welt der digitalen Fertigung, sei es 3D-Druck oder die CNC-Bearbeitung von Gitarren, seiner größten Leidenschaft.
Dean’s back with an exciting re-worked version of the Plywood Guitar, fondly named MK2. This one is crafted from recycled materials that originally made the stages and sets for the Commonwealth Games in Birmingham, UK.
"I've kept the neck dimensions the same as Mk1 but omitted the two side carves. The body is now even easier to manufacture using 10mm dowel pins. The face plate and back are made from a 9mm thick piece of wood; in the file, the cut is set to 10mm as I used a fancy leatherette veneered ply. I've also used 3.2mm pop rivets with the pins removed as string retainers."
Dean has also included the STL files for the bridge and the nut. The bridge uses an M6 Bolt as the string contact point, and both files can be 3D printed.
To keep up to date with Dean's projects you can check out his Instagram page here: https://www.instagram.com/dean_makes
Passend für Ausführung 12 oder größer
