3D-Lithophane aus Fotografien
Diese Fallstudie erklärt, was Lithophanien sind und wie diese unschätzbaren 3D-Bilder mit PhotoVCarve CNC-gefräst werden können.
With the ever increasing demand for unique personalized work, why not use your CNC router or engraving machine to carve stunning family portraits that will last for generations.
Family, friends and work colleagues will all want 3D Lithophanes of their loved ones carved into permanent visible memories that won't fade or age.
A flat piece of 18" x 12" x 1/4" thick Corian or Plexiglas costing around $10 can be transformed into a family treasure that looks beautiful and will last a life time!
What is a Lithophane?
Lithophanes are 3D photographs that when viewed in normal lighting look a little dull and lifeless. But when back lit transform into stunning 3D pictures with depth and detail that cannot be seen in a flat 2D photograph.Lithophanes originate from a process developed back in the mid 1800's for mass producing 3D pictures in porcelain. A 3D design was hand engraved into a thin sheet of bees wax that was placed over a lighted candle to show the effect of light passing through the wax. This master design was then used to make a mold for casting designs in porcelain. Varying levels of light to pass through the porcelain depending upon the thickness
The Greek origin of lithophane work means "light in stone" or to "appear in stone".
Examples of what lithophanes were used for include Decorative Lamp Shades and Window Panels that came to life when lit from behind and German Beer Jugs that had a translucent bases that turned into 3D pictures once the beer had been drunk. Very few of the original antique lithophanes have survived because the 3D images look crude and worthless unless held in front of a light.
For more information about lithophanes visit the The Blair Museum of Lithophanes and theWie Sie Ihre eigenen Fotos in 3D-Lithophane verwandeln
Geeignete Materialien finden
Damit ein Lithophan bei Gegenlicht oder von hinten beleuchtetem Untergrund zum Leben erwacht, muss das Material lichtdurchlässig, aber nicht transparent sein. Der 3D-Effekt entsteht dadurch, dass das Foto in den hellen Bereichen dünner und in den dunkleren Bereichen dicker bearbeitet wird. PhotoVCarve erledigt dies automatisch. Die unterschiedliche Materialstärke bestimmt, wie viel Licht durch das Material dringt.Das ideale Material für die Bearbeitung von Lithophanien ist 6 mm (1/4 Zoll) dickes, weißes Corian®, ein synthetischer Mineralwerkstoff von DuPont. Corian® ist schwer erhältlich, da es nur an Fachhändler verkauft und von zertifizierten Handwerkern verarbeitet wird. Viele Kunden wenden sich an lokale Küchen- und Badausstatter und kaufen dort Reststücke. Obwohl Corian® auf den ersten Blick zäh und schwer zu bearbeiten erscheint, lässt es sich zu feinem Pulver verarbeiten und ist sehr leicht zu bearbeiten.
Avonite® ist ein Material mit ähnlichen Transparenzeigenschaften wie Corian® und eignet sich gut für Lithophanien.
Auch Plexiglas oder Acrylglas (weiß, transluzent) können verwendet werden. Obwohl diese Materialien günstiger und weiter verbreitet sind, lassen sie sich oft schwieriger bearbeiten. Acrylglas ist als gegossene oder extrudierte Platten erhältlich, wobei die gegossene Variante deutlich einfacher zu bearbeiten ist, da sie nicht schmilzt und am Schneidwerkzeug kleben bleibt.Der Fräser muss sehr scharf sein. Kühlung mit einem Luftstrahl oder die Verwendung eines Schmiermittels erleichtert die Bearbeitung dieser Materialien.
Welchen Fräser verwenden?
Für die Bearbeitung einer glatten, hochwertigen Lithophanie sollte ein Kugelfräser verwendet werden. Generell gilt: Je kleiner das Design, desto kleiner muss der Fräserdurchmesser sein, um maximale Detailgenauigkeit zu gewährleisten. Je größer der Fräserdurchmesser, desto weniger Details werden bearbeitet.
Ein Kugelfräser mit 3 mm Durchmesser (1/8 Zoll) liefert eine gute Detailgenauigkeit bei Lithophanien ab ca. 250 mm x 250 mm (10 Zoll x 10 Zoll). Ein Fräser mit kleinerem Durchmesser ermöglicht zwar mehr Details, jedoch ist zu beachten, dass ein kleinerer Fräserdurchmesser zu einer geringeren Zustellung und damit zu längeren Bearbeitungszeiten führt.
Für kleinere Werkstücke wird ein Kugelfräser mit 1,5 mm Durchmesser (1/16 Zoll) empfohlen.
Kegelförmige Kugelkopffräser sind tendenziell robuster und weniger bruchanfällig, da die Schneide breiter/dicker und stärker wird.Klicken Sie hier für eine Liste der Werkzeuglieferanten
Die Bearbeitung von 3D-Lithophanen ist sehr einfach
Öffnen Sie ein digitales oder gescanntes Foto (Farbe oder Schwarzweiß) in PhotoVCarve
Geben Sie die gewünschte Größe an
Wählen Sie einen Kugelkopffräser aus der Werkzeugdatenbank
Speichern Sie die Werkzeugwegdatei und führen Sie sie auf Ihrer Maschine aus
Sehen Sie sich das untenstehende Schulungsvideo an, um zu sehen, wie einfach Lithophanen hergestellt werden können.
Beachten Sie, dass die Bearbeitung von Lithophanen in der Regel einige Stunden dauert. Die CNC-Maschine arbeitet jedoch unbeaufsichtigt, während Sie anderen Tätigkeiten nachgehen.
Online-Schulungsmaterialien für die Bearbeitung von Lithophanien mit PhotoVCarve
Dieses Video-Tutorial und das PDF-Dokument erklären Ihnen, wie Sie Ihre eigenen Fotos in beeindruckende Lithophanien verwandeln und diese mit Ihrer eigenen CNC-Maschine bearbeiten können.
Bei Fragen zu Lithophanien oder PhotoVCarve senden Sie bitte eine E-Mail an support@vectric.co.
m
